Taskbar Notifier
catsalleyt
Jan 26, 2008
50
Paloma, California
Hi,
First I wanted to thank Tinman for the help with the ZiPhone Jailbreak.
I have a 1.1.2 otb and it worked Great!
I really want to get the TASK BAR NOTIFIER WORKING. On the installer it has a version 0.8. It wont work for me. I read up on it and it said there was a 0.9 version out. How do I get my hands on it!
Thanks,
lman
Oct 18, 2007
632
Anyone have any success with 0.9 working?
MundoGrande
Jan 26, 2008
155
1.1.3 and it doesn't work. Anyone know why?
burniksapwet
Jul 5, 2007
553
me! I'm on 1.1.3 and it's workin' great! THIS is my most useful app. I WISH Apple did something like this.
Where did you get version .9? I don't seem to have it and I would like to find out what source you downloaded it from. Please tell me what source it came from. Thanks.
psylichon
Oct 31, 2007
16,591
751
40
Philly
Great app! Though I'm having a problem with it... I installed the latest version, but now I have a permanent email message indicator. It should only be there when I have unread mail, right?
edit: oops, there it goes. Just seems to lag a bit.
15,384
1,089
yeah, it does have a significant lag. i do know if you lock/unlock it usually goes away.
lman
Oct 18, 2007
632
Question, if your adding the file manually from the link posted earlier in the thread. Where are you placing that folder?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
It's in the readme file you downloaded as well. Can you not find it in installer yet? Try all packages by name (if you haven't done that yet)
lman
Oct 18, 2007
632
Yeah i tried following what the readme file said it didn't work so i tried installing it from installer again and restarting and it worked this time. Thanks.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
No worries. yes, you gotta reboot after the install.
Storm
Nov 20, 2007
14
Texas
Anyone have a clue where the program is? I need to modify the image files it uses. The one for Text Msg, EMail, Missed Call.. I can't locate it, been all over the thing with SSH..
eTEK
Oct 7, 2007
45
I download it and install it, but it doesn't appear on my springboard.
Any advice?
burniksapwet
Jul 5, 2007
553
Any advice?
This will not appear in your springboard. It will create an icon on the upper right hand side of your phone when you get a new text, email and a missed call. Go ahead and try to email yourself to so see if it works.;)
