Terminal (vt100) on iPhone
divabimbers
Sep 7, 2007
Arizona
Anyone know why I'm getting "/usr/bin/login: File does not exist" and "/bin/login" File does not exist"? Might this be because I need to install the BSD subsystem before I can start using VT100? I'm mainly interested in trying to use this to telnet into MUD servers though wonder if it could work on EDGE at all. At any rate, I'd appreciate any help since this could come in handier than I'd think once I start getting the hang of using terminal more and more.
divabimbers
Sep 7, 2007
Arizona
Duh, turns out I was right. It's working fine now although does anyone have any suggestions on how I can get more commands working? like telnet? I don't believe that command is in the BSD subsystem and I need that for MUDs. Also, what are some other cool things to do with terminal on the iPhone? Might it be possible to install some Unix CLI apps/games as well? Yes, I'm a bit excited but then again, I think this device has so much potential!
