Text Feature Failed To Upgrade
vball5153
Dec 6, 2008
Cincinnati, Ohio
After a few tries, my 3G seemed to upgrade successfuly. But I now notice that the Messages icon fails to have the SMS across it and I can't reply to texts I've received. Can I upgrade/update/repair just the text feature? Or should I start my 3.0 upgrade all over, and if so, how?
termleech
Sep 7, 2007
1,154
McPherson, KS
If you are referring to the icon for messages it doesn't say SMS anymore. As for not being able to reply. Does it give you and red arrow? Or does the progrma not load? Can you be a bit more specific
lhkm
Jun 17, 2009
14
mine did the same thing i don't have the sms across the icon any more, but as of now i can still receive & send text
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
That's because they changed the icon. You'll also notice it now says "Messages" instead of "Text" underneath it. Just part of the update...
lhkm
Jun 17, 2009
14
thanks for the info!
vball5153
Dec 6, 2008
Cincinnati, Ohio
Thanks for your quick response. Specifically, I get a text that starts a NEW conversation. But when I hit "Reply" no keyboard comes up. If I initiate the text, starting with my contacts, the keyboard does come up and I can send. When I respond to the response, the keyboard comes up. However, I just asked someone to send me a New Conversation test. He did, and when I hit Reply, the keyboard won't come up. That's it - unable to respond to some texts. What's up with that?
KabaModern
Mar 31, 2008
4,549
32
Hmm...that sounds very strange. Unfortunately, you cannot just repair a single application. I would recommend restoring the iPhone. Plug it into iTunes and hit the Restore button. Be sure to backup your iPhone so you can reload all your settings/applications, etc.
Let us know the outcome.
vball5153
Dec 6, 2008
Cincinnati, Ohio
I just tried to follow the advice to: "Plug it into iTunes and hit the Restore button." Can't find a Restore choice. Where's it hidden? I remember a Devices choice being there on the left which should lead to iPhone which should take me to Restore. But now I don't see Devices. Thanks for the help you're all providing.
KabaModern
Mar 31, 2008
4,549
32
Yes, correct. You should get a DEVICES label on the left hand side of iTunes. Underneath that you'll see your iPhone and if you click on your iPhone, you'll be presented with the main menu where you'll see the Restore button in the right-hand pane. It sounds like iTunes is not recognizing your iPhone at this point. I would try unplugging your iPhone and restart your computer. Once restarted, open iTunes and plug your iPhone back in, see if it shows up.
If it still does not show up, unplug your iPhone and put it into DFU Mode to prepare for a restore:
http://limitededitioniphone.com/how-to-put-the-iphone-into-dfu-mode/
Let me know...
