text msg display problem
Nov 24, 2007
319
hi all, i'm having a text msg problem . wondering if someone might be able to tell me how to fix it. its not serious but my texts are displaying all wacked... all received msgs stay at the top of the page & all the sent msgs stay at the bottom of the page.. i think the problem is the time some how...k its 2:15pm were i'm at... i sent a text at 2:12pm "happy easter" my reply from this msg says 10:13am "thanks".. its 4 hours behind for some reason... i also noticed when i sync in iTunes my time goes back 1 hour. it'll change as i plug it in, & will change back when i unplug it... anyone else have this problem?
aaronsiphone
Dec 28, 2007
297
search is your friend, try searching the forum for something like "sms order" or SMS problem" you will find liturally hundreds of answers on there. Sorry to be an ass but people don't seem to like replying to the same question over and over. little tip though, im guessing your on 1.1.3. update to 1.1.4
Nov 24, 2007
319
i have searched and didn't find anything .. i also just searched "sms order" or SMS problem" and still haven't found anything on how to fix it... ya i'm on 1.1.3
aaronsiphone
Dec 28, 2007
297
in that case go with what I said update to 1.1.4 problem sorted
Nov 24, 2007
319
can u post a link on how to fix it for 1.1.3, if it can be fixed.. i'm not updating to 1.1.4.. i finally just got 1.1.3 how i want it..
aaronsiphone
Dec 28, 2007
297
im not sure there is a fix, my fix was to update to 1.1.4 nothing really changes apart from fixes etc and you can get 99% of your apps back if you are jailbroken which i guess you are
Nov 24, 2007
319
ya i'm unlocked/& jailbroken... i live in canada so i have no choice... i have to restore to 1.1.3, than restore to 1.1.4 , then ZiPhone... not ready for that just yet, maybe at 1.1.5..
CBRfanatic
Feb 28, 2008
302
Bronx
there will be no 1.1.5, its going straight to 2.0 with the major enterprise release. if you don't want to upgrade then you will have to keep getting your sms' like that
Bone
Feb 11, 2008
1,214
There is no fix for the scramble in 1.1.3. The only option is to update that I'm aware of.
Nov 24, 2007
319
i guess my next upgrade will be 2.0, lol i like the sound of that.. i'm just thinking but i won't be able to use SDK anyways... you have to be unlocked & jailbroken in canada...
