"The application cannot be opened"
Velodog2
Jul 19, 2007
562
I am getting this message every time I try to open some of my apps. So far I've discovered it with Cubes and Oscillator. These are both apps that previously worked fine. I synced with iTunes but it didn't help.
Jhors2
Nov 11, 2007
239
I had this happen to me with AIM, I had to uninstall it on the phone and reinstall it to get it work again....
jester310
Aug 9, 2007
this is happening to me with the myspace app
styfle
Mar 31, 2008
3,381
the first thing to try is turn off the phone, wait 30 seconds, turn it back on
if that doesn't work then go ahead and delete it off the phone and reinstall
Dec 4, 2008
it has been problem with me in all the application.. am not able to add any application from iTunes.. i patched mibileinstallation file also...
downloading from cydia or installer n installing doenst have ny problem in opening only if i add ipa file to iTunes n than sync icon will appear in my iPhone but gives same error message cannot be opened.. ny idea ppl pl help,,,,,,,
