the solution of "Repair Needed" msg. 3G iPhones
deadstar
Feb 16, 2009
TURKIYE / AUSTRALIA
hey folks.
Recently i received that annoying message and i figured out the solution by myself.I hope that this works for you too.
(FOR LEGAL iPhoneS, NOT CRACKED)
1-Open iTunes. (not plugged in the data cable)
2- Turn off the iPhone
3- hold down the home button 5-6 secs, then plug in the data cable.
4- Keep holding down the home button and wait 5-6 more.
5- you'll see the message that you need to connect it to iTunes.
6- plug off the data cable and plug in again.
7- iTunes says that iPhone needs to be restored
8- click restore and da taa.. everything works fine.
I haven't tried this on cracked versions but, logically, if you install the ipsw file manually, this may works too.
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
hey folks.
Somethig just dosent seem right about this post.
deadstar
Feb 16, 2009
TURKIYE / AUSTRALIA
hmm.. what you mean?
i just wanted to help the people who received that message. if you want,you can delete my message.
cheers.
D,
6,682
49
That message is not like getting the "connect to iTunes" message. Most of the time, the Repair needed message indicates a larger problem that cannot be solved doing a couple of restores. It's generally an indication that the baseband is corrupt or dead. Rarely, if ever, does putting the phone in DFU mode, restoring, and then restoring again, fix the problem. 99.9% of the time, the phone has to go in for repair.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Thanks for the info Hawk. I had never even heard of this message before. Always learn something new here.
6,682
49
No Problem. This was the error message I was getting on my V1. I watched the signal die, did a hard reset, had to restore, and ended up with that message. I never did get it working again, and the option to have Apple service it versus the cost of a new phone was not an option. I got a new 3G.
deadstar
Feb 16, 2009
TURKIYE / AUSTRALIA
first, i got the message "REPAIR NEEDED" (iPhone cannot make or receive calls) contact : Apple,com/support... No IMAI and no ICCID number showed. I tried to restore using iTunes but a sim card warning popped up. Then, i tried to restore manually, and it worked.I mean, I tried that method. Maybe, it was my luck. anyways.
