The top half of my old iPhone won't work
The1dym
Sep 12, 2011
Idk witch type of iPhone I have i got it from my bro but it's old. So I went in the pool and I forgot I had it in my pocket. Now the top half of the screen doesn't work. Is there any hope!?
Lon
Jun 5, 2010
2,946
132
Alaska
If on you should turn it off immediately and not restart again until after you have put it in a baggy of rice for 2-3 days. That might be your only hope, though it sounds like you have started it already since you know the screen doesn't work. It may have irreparable damage already. Give the above rice baggy a try though.
The1dym
Sep 12, 2011
This was a LONG time ago idk if the thing with the rice will work but ama give it a try
