The volume became very low from iPhone 5 headphones
rugved1118
Sep 27, 2013
642
Hello,
The overall volume of iPhone5 headphone became low all of sudden. It was working fine until yesterday. Its the same when i connect to my ipad2. But both speakers of headphones are working fine. I mean, there is no disconnection of the wire also.
Can anyone advice what might be the reason ?
Sent from my iPhone using iCafe Forums
Proud owner of iPhone5, iPhone4 and ipad2-wifi+3G
Ledsteplin
Oct 29, 2013
4,823
987
65
Florence, AL
Hello,
The overall volume of iPhone5 headphone became low all of sudden. It was working fine until yesterday. Its the same when I connect to my ipad2. But both speakers of headphones are working fine. I mean, there is no disconnection of the wire also.
The EarPods that came with the phone? If volume on the phone is turned all the way up, check the up volume on the earpod wiring. Also, go to settings>Music>turn off EQ and Volume Limit. Also check each ear piece for debris, lint and ear wax.
28,365
5,506
Get a flashlight and make sure there isn't dust and lint inside the headphone jack port on the phone. You'd be amazed how much can accumulate there. You can use an extended paperclip or something similar to remove it.
Also try cleaning the headphone jack.
Ledsteplin
Oct 29, 2013
4,823
987
65
Florence, AL
I would have suggested that, but it did the same on another device. But I suppose 2 devices could have a clogged port.
28,365
5,506
It's probably more likely that the headphones are bad. The easiest way to tell is to plug in an alternate pair of headphones.
rugved1118
Sep 27, 2013
642
I tried using alternate headphone on my iPhone and ipad and have figured out the sound is amazing. This confirms that there is surely some problem with my iPhone headphones. Will try cleaning it. Might as well havr to use magnified glass to clean the pores i guess ;)
rugved1118
Sep 27, 2013
642
I tried using alternate headphone on my iPhone and ipad and have figured out the sound is amazing. This confirms that there is surely some problem with my iPhone headphones. Will try cleaning it. Might as well havr to use magnified glass to clean the pores I guess ;)
It worked for exactly one year and don't know what went wrong all of a sudden, the volume became very low. If there had been cord discontinuation, then either one of one side would have not been working, but thats not the case. Its quite strange !
Ledsteplin
Oct 29, 2013
4,823
987
65
Florence, AL
Maybe they're just worn out. The volume buttons on them may be messed up.
rugved1118
Sep 27, 2013
642
The volume button is also working fine. I tried them by increasing and decreasingthr volume.
28,365
5,506
It's not that unusual for both sides to go bad at the same time. I've had it happen.
