Theme and picture
Do you mean change the wallpaper that was included with a theme to one of your own wallpapers?
Uncheck the theme in WinterBoard then hit the respring button. That will disable the theme. Once the theme is disabled you'll be able to change your wallpaper again. You can change a wallpaper that's included with a theme, but the process is different from how it's done when you aren't using a theme.
iNurse
Nov 11, 2011
559
The Volunteer State of Tennessee
That worked on the picture on home screen! Thanks!
