Theme creating help...how to change "slide to unlock" etc?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I've been doing a lot of my own themes lately and there's one last thing I'm trying to learn how to do. How do I change the messages that are with the sliders ... the "slide to answer", "slide to unlock", etc. I know there have been apps in the past that let you modify them but I want to modify it within the theme itself so that when someone downloads it from Cydia it will be there.
If someone know how to do this please help me out. Or if someone knows of a theme on 3.0 that does this let me know the name so I can look at the way its built.
Thanks.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
What you want to do is create a folder in theme called "Bundles" (if you don't already have one created. make another folder inside it called "com.apple.springboard". Then a final folder called "en.lproj"
Add this attached file in en.lproj and you can modify it to how you want.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Ok so the file looks like this (I opened with notepad):
"AWAY_LOCK_LABEL" = "";
"POWER_DOWN_LOCK_LABEL" = "" ;
"SLIDE_TO_ANSWER" = "" ;
"SLIDE_TO_LISTEN" = "" ;
"SLIDE_TO_CALL_BACK" = "" ;
"SLIDE_TO_CANCEL" = "" ;
"SMS_LOCK_LABEL" = "" ;
What exactly do I do to change the "slide to unlock"?
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
whoops...it's still early. (just woke up 30 mins ago) you need to add the text you want here
"AWAY_LOCK_LABEL" = "Slide to Unlock";
type what you want where it say's slide to unlock. the "" is what set to show the default string.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I'm assuming I'm supposed to be doing this ...
"SLIDE_TO_UNLOCK" = "Energize" ;
Right now it's just making the string blank.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
No, scratch the SLIDE_TO_UNLOCK bit. It needs to be done under AWAY_LOCK_LABEL. Then it'll work. (like i said i just woke up shortly after i posted) :D
"AWAY_LOCK_LABEL" = "Energize";
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
"AWAY_LOCK_LABEL" = "Engerize";
"POWER_DOWN_LOCK_LABEL" = "Beam Me Up Scotty" ;
you just need to modify the file to look like that...
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Ok I got it working...thanks.
What's slide to listen? Voicemail message?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
The Bundles file goes in the main theme folder. Here's the folder order ...
Theme Name > Bundles > com.apple.springboard > en.lproj > PUT SPRINGBOARD.STRINGS FILE HERE.
Aug 13, 2009
Thank you guys for the hint I have done my own theme and used the above to change the slide to unlock text thank u so much.
but i want to know where to add the images needed for the slider and the slider bg :(
i couldn't find it anywhere else.
thanks a lot
Nov 17, 2009
How did you change the button slider to the ship? I'm making a futurama one and would like to put the Planet Express Ship there and i have the image i want, just don't know how to do it.
