theme/icons? and slider text help
unplug
Oct 12, 2007
14
Oct 4, 2007
537
San Francisco
u can change the slider text by using an application called customize. U can download customize via installer
patrick_83
Oct 11, 2007
310
Illinois
hey i was wondering if any1 knew were i can get this icon set..
http://i20.tinypic.com/28wnjlw.png
also i was wondering if any1 knew how to change the slider text image..
exmaple.
http://img507.imageshack.us/img507/521/lockedvx1.png
for the slider text if any1 can help me make it ...i lost photoshop cd..and i got slow internet so hard to download :p
The icons come from PlainJainDim theme, which you can get via installer.app.
The slider image you can modify through customize, or if you can find the directory where the slider image is. I was trying to find it but can't atm.
unplug
Oct 12, 2007
14
not the slider image itself
but that text
which says
"slide to unlock"
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
but that text
which says
"slide to unlock"
Here is the directory to the Slider Message thing that you are trying to change. Download the file and then open it up in Word Pad and then you can edit it to whatever you want. Just search for the "Slide to Unlock" and such and type in what you want.
System/->Library/->CoreServices/->SpringBoard.app->English.lproj/->Springboard.strings
