Theme icons
Flash52
Feb 24, 2010
20
ohio
Hi folks,I installed the theme SILent NiTE v2 on my iPhone 5 ios 6.1 and when I used winterboard to activate it only the background changed and the icons stayed the same.Would anybody have any ideas that I could try to get the themes icons to show up. I am jailbroken. Thanks!
5,580
The theme was probably made for a previous firmware version. Apple often changes the names and locations of the files with each new firmware. This makes certain elements of the themes incompatible. You can fix them yourself, but it can be a lot of tedious work and you have to learn the file system before you can do this. It's easiest to just make sure the themes you are downloading are made for or updated for your firmware version.
Flash52
Feb 24, 2010
20
ohio
Thank Europa,I guess I will look for another theme.Happy Thanksgiving !
