themes (customize)
fsas06
Oct 15, 2007
604
Las Vegas
were are the files for the cust. themes ?
i want to put the battey i DL in there
Oct 4, 2007
537
San Francisco
the file for customize battery images is located in:
var/root/library/customize/BatteryImages
fsas06
Oct 15, 2007
604
Las Vegas
ok, now that i put the file in there, it shows a pic of every "step" of the battery, insted of a preview, how can i fix this ?
and thanks for the help
Oct 4, 2007
537
San Francisco
did you create a new folder in the BatteryImages section of customize and then put the battery pics in that folder?
fsas06
Oct 15, 2007
604
Las Vegas
yes, i dono, i even tryed a diff. battery and it still shows up like the batman one, and im supost to do something else after i put it in or somethink with the file ?
fsas06
Oct 15, 2007
604
Las Vegas
i got the carrier logos to work, but not the battery lol
Dec 10, 2007
710
blacked out
Just a thought, but I had problems viewing an icon I installed for my SMS. The problem was the Summerboard theme I was using. It had a lock on the icons. IF you're using Summerboard, try changing your theme to the default and see if it works then.
azureshakr
Oct 31, 2007
do u have an original png image in the folder. u should have a x.png, x-1.png,x-2.png, x-3.....and so on using x as just an example, so yurs might say batman.png or something but the name of the file is not important. the -1 parts of the file are all of the different stages of the battery up to 16 or 17, but u have to have a preview pic in the folder as well, so make sure u have a .png file for the battery because thats the image that will b used for the preview when u look under customize.
fsas06
Oct 15, 2007
604
Las Vegas
ill look, i don't think i seen one, but if there isn't how do i get one ? just open one of the full battery pics and then save it with that name ?
Oct 30, 2007
the battery isn't working because your files are not formatted for customize..
the format goes as follows..
if the battery name is "batman"
then you should have batman-1.png, batman-2.png...batman-16.png in increasing order of course..and the full battery image should be simply called "batman.png"
so in all u should have 17 images..the full battery image called "batman.png" and the rest in ascending order from batman-1.png to batman-16.png
upload to customize directory and your good to go
Oct 31, 2007
yeah...u can do that, but u have to make a copy of it because u will still need that image as your batman-17.png file. so ...just make a copy and name it as batman.png and put it in the folder.
fsas06
Oct 15, 2007
604
Las Vegas
i still cant get it to work...owell..looks like no batman battery 4 me lol
Oct 31, 2007
really..thats very odd. r u not able to c the preview or is the battery itself not working? just a curious question though, does your battery files have a dash (-) or an underscore (_) after the batman part of the file? in customize, all the files must be a dash or it wont work. if yur trying to replace the main system battery not using customize, the file must be an underscore. thats the only other thing i can think of.
fsas06
Oct 15, 2007
604
Las Vegas
ok, well it fixed that now there is only one picture, but i still cant get it to work
