There may be an updated version of iTunes, depending on how you check...
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
If you check here:
it tells you that iTunes 12.3.1 is the current version.
If you check via the Mac App Store, it tells you that an update to 12.3.2 is available.
"It just works."
Right.
28,365
5,506
"It just works."
Right.
Jeez, give Apple a minute to push it to the app. You checked for it moments after it had been released. I don't have any fancy red arrows, but mine shows the update is available when I select "check for updates."
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
Just to make sure I didn't confuse anyone (Not talking to you, Europa, I know you're set), yes, there is an update, and I successfully installed it. :)
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Like Europa implied, it takes time for updates to propagate; it's not instant. Don't be so quick to jump on Apple. The update propagated pretty quickly, so in my opinion, the process "just worked".
dmoskaluk
Mar 22, 2013
305
45
65
Paynes Bay - Barbados
I had be on Yosemite on the iMac and maybe a week (or two) ago the El Capitan OSX update was pushed.... The iTunes update was shown in the list of packaged updates ( as well as updates to Safari and a Security update..... So all were done at once.
