Thin form factor that protects
TheJustPull
Oct 12, 2011
103
I work in a factory and need to put a case on my white iPhone 4. I don't want something too bulky but I would like it to offer a little protection if possible as well. Any suggestions? Also what's the best brand car charger?
jaydoc1
Sep 23, 2007
608
Seidio makes a nice thin protective case called the active x. Lifeproof cases are very popular and they REALLY protect.
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
LifeProof cases have the best protection for the size. Check em out at LifeProof.com. Slips into and out of the pocket easily.
Target
Oct 16, 2008
1,139
161
The Great State of WV.
I have actually tested and passed the water test. But it was with an A-. Little droplets on the pad at the charge door.
Target
katelynneemma
Jan 15, 2011
683
98
32
N.Y.
I have a bunch of cases but always end up going back to my Incipio silicrylic. it's slim enough to slide in my pocket but protects the phone from my 4 year old.
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
Target
I've seen that happen. The tiny little droplets are actually just water on the case outside of the seal that's been shaken off and landed there by opening the charge door (because opening it has a kind of springy effect). If the waterproof seal were actually broken, it wouldn't be droplets there.
TheJustPull
Oct 12, 2011
103
How about something made by griffin? I got a case as a gift that is the form factor I'm looking for and wondering how much protection it offers.
canamera
Dec 28, 2009
2,756
79
44
Toronto Ontario, Canada
Well searching just this forum finds several failed tests. There are more on larger forums.
Most failed water tests are from installation errors! In the 1000's of Lifeproofs sold, I doubt that there are even a handful that failed the water test legitimately. LifeProof has stated over and over again that each and every case is 100% water tested before packaging...
I have been LifeProof'd since April, and I have many LifeProof cases, and non of them failed. Some users have come back after failing the water test the first time and admitted that they either forgot something or didn't snap it shut (the honest ones atleast).
I will never buy another case again for my iPhone...there simply isn't a better case on the market that offers the protection LifeProof does. Just to add...I'll probably only buy a phone according to what LifeProof is protecting anyways....you get to used to the freedom o not having to worry about NOTHING.
MuddyPaws
Oct 3, 2009
986
31
I haven't seen one in person. The concept intrigues me but I know me. If it says I can swim with it, then I want to be able to do that. But I don't think I could actually bring myself to putting it under water to test it. So I would end up treating it like it wasn't waterproof anyway...more like water resistant. I've used and OtterBox since they started making them for the iPhone and have never been disappointed on how they hold up or protect. They are far from thin though but I actually like that. Makes me drop the tiny iPhone less often
canamera
Dec 28, 2009
2,756
79
44
I used to think the same way before getting my first LifeProof...no way was I going to put my phone under water....but as long as you do the test PROPERELY, and it passes, then you have nothing to worry about.
Lol....I actually find myself laughing now when someone actually compares LifeProof to Otterbox....no way on earth does Otterbox even come remotely close to protecting your iPhone the way LifeProof does, and in a more elegant manner. I can't even remember where I left my defender when I first put on my LifeProof...it was brand new too...
MuddyPaws
Oct 3, 2009
986
31
I'm not comparing the 2 really although from a rugged standpoint the Otter is pretty damn good. Not waterproof by any means but you don't have to worry about dropping it.
Has the Gen 2 lifeproof correct the echo problem that many people had? I don't know much about it but google finds a lot of complaints about it.
  • Like
Reactions: canamera
canamera
Dec 28, 2009
2,756
79
44
The echo problem was supposed to be corrected in the first Gen too. The purpose of Gen2 was to add two bumpers to protect the volume, and vibrate switch. Some people have had the echo problem, but out of the thousands of cases LifeProof has sold, the majority does not. I, myself have never experienced it. Either way, LifeProof has always taken care of their customers, and will exchange any defective cases.
MuddyPaws
Oct 3, 2009
986
31
I am starting to waver from my beloved otterbox. :D
Gotta do a bit more research. Then try to talk the wife out of 100 bucks. LOL
  • Like
Reactions: canamera
Simpleman
Oct 13, 2007
45
California
Just received my Lifeproof Gen2 for my iP4s an hour ago. I am thoroughly impressed with the thin profile and superior protection. It passed the waterproof test, sound quality is excellent. Yes, its pricey but so is replacing a broken iP4s.
regards
  • Like
Reactions: canamera
