This Accessory May Not Be Supported
bulls6pack
Jan 27, 2009
154
Peoria, Illinois
I just bought my iPhone 6, 3 days ago on Thursday, and today I began getting this message while trying to charge, This Accessory May Not Be Supported. It's not generic chargers either, it's the Apple charger that came with the phone, and old Apple chargers I had. None work. I'm down to 16% battery now. Anyone else experiencing this? Thoughts, suggestions?
Dec 15, 2008
5,386
340
Pensacola, FL
I haven't had this occur with an Apple made charger, but I read on here if an Apple charger breaks or stops working, they should replace for you.
Does it still charge for you and then tell you that message?
silvermoon
Jul 17, 2013
1,624
179
Washington
I'd take the charger into the Apple store and have them replace it for you. I haven't experienced this with any Apple chargers. I'm sure you already know this but make sure it's an Apple charger and not a generic brand.
djwindsor
Jul 7, 2009
755
44
Neponsit, NY
Funny thing is that I got this message too! It was with an apple sanctioned cable (not OEM but bought at their store). I got the message when utilizing an external battery pack. I rebooted the phone and resumed the charge when I got home.
5,578
Just to clarify - the Apple charger and the Apple cable that you got three days ago will not charge your phone and you get Accessory May Not Be Supported popup when you try to use them? If you are you anything other than these two, try them together. Do not use a USB hub or an accessory to charge. Just connect the phone to the wall with the charger and cable it came with. There may be a problem with your old cables or charger. Post an update after trying this.
bulls6pack
Jan 27, 2009
154
Peoria, Illinois
It was the apple usb cable and wall charger that came with the phone, and also the one that came with my iPhone 5, my griffin car charger that always worked with my 5, and another apple usb cable at my computer. None are working! Getting really annoying though. This should never happen with Apple chargers. To top it off the iPhone 6 is only 4 days old!
5,578
Okay, so you have no way of charging your phone? Have you tried charging it on a computer? Make sure there is no lint or anything else obstructing the charging port.
Have you tried it without a case? Your case might be obstructing the Lightning cable.
You'll need to take it to Apple if it won't charge and iTunes won't recognize it. It sounds like there is a problem with contact on the charging port.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Try to see if something got inside the port. I had that same problem for months till I decided to finally get a genius appointment. Lint was blocking the connector.
Ledsteplin
Oct 29, 2013
4,848
1,002
66
Florence, AL
I started getting "the message" with my monoprice MFi certified cable I had been using months with no issues. After examination, the area where some put pen springs was unraveling a bit. I taped it good with electrical tape and all is well. No more "message".
Sent from my ancient but trustworthy iPhone 5.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
My Lightening cable started doing the same thing at the Lightening connector end. The strain relief was still firmly attached to the connector body but the cable was pulling out of the strain relief. I was able to slide the cable back in and wrap it tightly with a couple rounds of electrical tape, I was barely able to slip an inch and a quarter long piece of shrinkable tubing over the lightening connector, butt the end of the tubing up against the connector body and shrink it in place. I then did the same thing on the USB end of the cable as a precaution. Black shrink tubing on a white cable may be a little ugly but zero problems for the last several months.
Ledsteplin
Oct 29, 2013
4,848
1,002
66
Florence, AL
I'm gonna have to get some shrinkable tubing. I'm not familiar with it. Seems like it would help on these cables.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
It's sometimes called heat shrink tubing. Heat from a cigarette lighter flame gently applied will shrink it. It comes in many different colors and sizes. Radio Shack has a nice package of assorted sizes from 1/8" to 1/2" and it can be found in hardware stores, Home Depot or Menard's as well. Good luck.
Njshoremom4gurlz
Sep 13, 2011
536
84
Got the message too changed chargers message is gone it's an 8.1 thing it happened w the 5s too
iphonewarrior
13,847
702
I've used heat shrink on my original iPhone 5 cable - I used two pieces at different diameters and shrank the first part and slid the larger section over the top of the smaller bit to make a nice solid cover. It really does work :)
BobsApple
Nov 9, 2014
17
San Francisco Bay Area
I had the same thing happen with my car charger on my previous Iphone 5. I unplugged it, put back in and it was fine. However my cable was in bad shape and replaced the cable.
Yours, only 3 days old, I would return it to Apple for a exchange.
BTW, I try to be very careful with that connection, on both my IPad and IPhone 6 due to the fact that it looks like the charge socket could be damaged easily.
Best
Bob
