This is how to jailbreak a 1.1.2 otb iPhone...
Chris716
Nov 29, 2007
807
IL
Im writing this because ive helped about 7 people the past two days doing this and im doing this to save me some time too...
OK if you have bought a iPhone and you want it to be jailbroken and your firmware is 1.1.2 just follow my directions here and you will be jailbroke in no time at all....
First thing you want to do is download Firmware 1.1.1 this can be found here.. http://appldnld.apple.com.edgesuite.net/content.info.apple.com/iphone/061-3883.20070927.In76t/iPhone1,1_1.1.1_3A109a_Restore.ipsw
that is the link for 1.1.1
First thing you want to do is connect your iPhone to your cpu and hold the home button and the power button for about 10 seconds when the screen goes black release the power button but continue to hold the home key until you see a message saying that there was an iPhone found in dfu mode or restore mode..
After you see that you want to hold shift and click restore and restore phone to the 1.1.1 software that you just downloaded.
At the end of the restore you will get an error messge 1015 this is good.
next you want to close iTunes and make sure its closed..
Now you want to download app tapp it can be found here....
http://www.nullriver.com/~adam/AppTappInstaller.exe
now run app tapp make sure you select firmware 1.0.2 in app tapp even though thats not the firmware you have your doing this to bring the phone out of recovery mode...
if you get a message saying to close iTuneshelper open iTunes an close it again an run this program.. You will get a message saying send to iPhone failed this is good....
At this point close iTunes and unplug the iPhone from the cpu.. On your screen you will see that it says slide for emergency... Connect your iPhone back to the computer and open iTunes and your phone will now say waiting for activation.. Now you can slide the slider to get to the home screen...When you get to the home screen on your phone the phone wont work at all....
So now turn on the wifi on the phone and go to jailbreakme.com from your iPhone... Once your on that site scroll to the bottom and click install for that program on the bottom.. its called appSnapp
Once this is installed you will see installer on your home screen of your iPhone.. Click this and go and click all packages and scroll down till you see OKtoprep and click that and install it. A message will pop up saying you are ready to upgrade to 1.1.2.
At this point go back into iTunes and click upgrade and upgrade back to 1.1.2 this will take a lil bit for it to finish but just wait..
Once this is finish you will see that installer has disappeared from your iPhone home screen don't think that you did something wrong because you haven't.
Next you want to go to this site right here http://conceitedsoftware.com/iPhone/1.1.2-jailbreak.zip and download the software right on that screen...
Once that software is installed on your cpu open that file up and click on windows.bat and it will ask you if you want to run it or exctract all.. You want to extract all...
Right Now close iTunes all up and Open that file you just extracted and go to the windows.bat file and click it again this time click run... A black command box will pop up and another box will pop up on this box it will ask if you if you want to reboot or jailbreak on the bottom of it and just click the jailbreak button...
Now the software will run it will take about 5-8 mins or so to do its thing durning this time your iPhone will reboot a couple times and when you see that your iPhone has came back on Your all done you will see that the black command box says rebooting iPhone and it will be done if your iPhone is just sitting on now and not rebooting... Now you can close that black command box and your all done..
You will Now see the installer icon on your home screen again....
Congrats your done....
have fun customizing your iPhone if you need any help feel free to ask me but try the above steps first thanks
connie
Jul 11, 2007
2,839
104
So Cal
Thanks for posting this, I will try it tomorrow.:)
Chris716
Nov 29, 2007
807
IL
yes no problem if you need help just send me an im or something ill be around
termleech
Sep 7, 2007
1,154
McPherson, KS
We should sticky this. I can't count the number of times the question is asked and I point to the same posts over and over again.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
FINALLY made the leap from my modded 1.0.2 to a jailbroken 1.1.2 and it went flawlessly. I stand and applaud these efforts!:laugh2:
connie
Jul 11, 2007
2,839
104
So Cal
After doing the apptap it says apptap failed and my iPhone screen does not go home it says plug in to iTunes to activate phone. Any ideas on where I went wrong or where I go from here?
Guest 6
Jul 21, 2007
wow took a while, with a bit of trying this & that before i got these instructions to work.. but it's all flying colors now! thanks! i upgraded from 1.0.2 to 1.1.2.
Jul 6, 2007
1,832
26
Marietta, GA
about.me
At this point go back into iTunes and click upgrade and upgrade back to 1.1.2 this will take a lil bit for it to finish but just wait...
i am following this method exactly as it says, but i hit update to 1.1.2 and its taking more than just a little while. it was about 1 hour, then about 30 mins into it, it said done and that the file was corrupt so i had to unplug my iPhone and hit update again an download the file all over again and i am wayyy too impatient to wait another hour for this. is it supposed to take this long?
ps. im not downloading anything else, the only thing i am doing on the pc is downloading that, listening to music, and posting this
Chris716
Nov 29, 2007
807
IL
its suspose to take like 10 mins max
if you want me to help you i will just pm an aim or yahoo name and ill help you
iCafe
Dec 11, 2007
1,877
www.wwtdd.com
Hey chris, thanks a lot for walking me through it on AIM
couldnt have done it without your help
kbhark
Jun 28, 2007
55
My phone is currently running 1.1.2. So after I update back to 1.1.1 and download installer, do I have to download OKT and update to 1.1.2 again for it to work or can I just keep it at 1.1.1? And If I have to restore, will it brick the phone updating back to 1.1.2? Also does this process work on a Mac or just PC? Any info would help. Thanks in advance!
Chris716
Nov 29, 2007
807
IL
you have to do what i said because if you keep it at 1.1.1 your phone wont even work or anything only thing that will work will be wifi
NickB
Nov 28, 2007
89
Wow, awesome! Thanks for stepping me through the snag Chris! If you ever need any help concerning car audio/electronics shoot me a pm, i owe ya one.
Chris716
Nov 29, 2007
807
IL
yeah no problem at all... Hope you enjoy your jailbroke iPhone... You know my AIM name so if you need anthing just im me... Later......
