Time Problem?
SpyderDriver
Jun 28, 2007
24
Does anyone else have issues with the time in the header bar at the top of the Home screen? Mine doesn't seem to be correct but I can't figure out why?
When I wake the phone up the correct time shows. Then I slide to unlock and the home screen shows. The time that appears at the very top is like 4 hours off. Is this set somewhere? I have the time set to auto set.
Any ideas? Did I miss something?
SpyderDriver
Jun 28, 2007
24
ok I figured it out. It was holding bad time for some reason.
i went into settings and told it not to auto set then flipped it back to auto set.
That made it finally work. Just FYI
