Tips for fixing slow Internet on MacBook
bronxaccents
Sep 6, 2007
60
New York City
im not too sure whats going on but until the past 3 days the internet on my new macbook is going slow , the pages take awhile too load for some reason. i never had this problem before, usually its pretty fast. i use firefox if that helps. anyone know what might be wrong?
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Are you clearing out your history,cache, and cookies every few days? How long have you had your MB.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Also, are you sure it's not the actual internet speed? Try resetting your router and your modem, that might help a bit.
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
Along with Youngbinks' comment, go to a internet speed test site to confirm your download and upload speeds.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
im new to a mac, ive only had it for about a month. where do i go to clear out the cache,history&cookie files?
You can clear history by going to history at the top of the safari page. At the bottom it says clear history. The cache can be cleared by using the shortcut option-command-,.This will bring a popup asking if you want to clear cache. Cookies can be cleared by going to Safari-Preferences-Security. There you will see a place to click that says show cookies. Click on that and then you will see remove all. Click that.
Or you can go into Safari > Reset Safari. That removes all of them.
- John
dturner
Dec 15, 2007
5,725
Louisville, Ky.
- John
I have notice the Reset Safari but didn't know what it would do, so never used it. Defiantly easier that my way.
kokogirl
Sep 8, 2007
2,319
47
Sunny Florida
I have never cleared cache or cookies. Is this important? If yes, why?
15,384
1,089
It's one of the first troubleshooting fixes to perform if you're experiencing weird internet problems, because it's easy to do, and often gets your browser back to working normally again. If you're noticing your browser slowing down some, or getting new popups, or certain websites blocking access, or anything like that, give it a shot.
Otherwise, if it ain't broke...
dturner
Dec 15, 2007
5,725
Louisville, Ky.
It is also good to do on your phone every so often. You can do that in settings-safari. At the bottom you will see the three places to clear.
