Total Noob question, loading music
Oct 1, 2008
I can't just drag and drop from iTunes onto my iPhone, am I doing something wrong?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
You don't drag and drop into the iPhone, per se. You drop the music into iTunes and then sync your music, playlists, etc with the phone. Make sure you have you have the music syncing option checked:
Plug into iTunes, click on the iPhone on the left hand column, then click on the music tab and make sure you have "sync music" or something like that checked.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
I believe you can if you check "manually manage music" on the main page near the bottom when your phone is connected.
Oct 1, 2008
i have 146 Gb of music on my iTunes, so I can't just synch it, I need to manually manage it, i'll look for that tab that will let me do that.....
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
You can do it all in that tab. Just select the music/playlists you want.
MileHighRob
Jul 16, 2008
1,592
Colorado
It's on the first page when you plug your phone into iTunes... you've got options to:
Automatically sync
Manually Manage or
Only sync checked songs
I can't remember the exact wording because I'm away from my computer right now but those are the basic options when you plug the phone in.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Or you can just check the albums you want and use the "sync checked songs" option.
Tug
Aug 4, 2008
528
146GB's? How many flippin' songs is that?
Oct 1, 2008
its a lot, but i have friends with WAY more than that, i have 2 buddies who have almost a terabyte between them. they basically collect music. when they hear somethign new that they like, they find anything they can by said artist. its pretty intense.....
