Touch ID won't recognize my fingerprint
dinosaur1
Nov 10, 2007
516
I tried with 3 different fingers and my fingerprint reader doesn't work. Help! What am I doing wrong?
Sent using iCafe app
Docd
Oct 16, 2011
651
66
Make sure are leaving finger there until it vibrates before you lift it each time when programming your print.
Sent from my iPhone using Tapatalk -
dinosaur1
Nov 10, 2007
516
Tried still won't work. When the screen is off how do I do it the correct way?
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
You have to press the sleep/wake button. With the iPhone awake, press your finger lightly on the home button/fingerprint sensor.
You made it through the setup process ok? Your fingerprints are registered?
dinosaur1
Nov 10, 2007
516
I did all of that and nothing. I see others are having issues as we'll.
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
I'd suggest setting up a new fingerprint. When you do, be sure to move it around in between each scan. This will allow Touch ID to get a better scan and might be less temperamental when you try to unlock your iPhone.
I did have an issue with my first fingerprint. Odd, it was set up and nothing I did would make it recognize my finger. I haven't had an issue after rescanning, so maybe it has something to do with the scan.
dinosaur1
Nov 10, 2007
516
I tried using different finger still nothing. Is the phone defective?
