Transfer Contacts From Vista To Mac
TimmBxX
Dec 25, 2007
53
So I am getting a MacBook this weekend. I will be using it as my primary computer, but right now my primary computer is a Gateway w/ Vista.
I know that when I plug my iPhone in I will have to reformat it, so I will loose all of my information. This isn't a problem, as I will just put my music onto the MacBook. But is there a way to transfer my Windows Vista contacts onto the MacBook so I don't have to re enter all of them into my new computer?
geordisjd
2,442
You shouldn't have to reformat your iPhone. It's the same for Mac and PC. When you first connect it to the Mac, iTunes will ask you if you want to replace the info on the phone (no!) or merge (Yes!)your contacts/cal/bookmarks info (the stuff under the "info" tab).
I forgot to say: welcome to the Mac world.
TimmBxX
Dec 25, 2007
53
Thanks! I guess I should have done a little more searching, found the same type of question under the Mac category! Thanks for the help
