Transfer iPad to iPad
theorioles33
Jul 21, 2007
925
135
USA
You would have to do a backup from your old ipad to either the cloud or your computer and then restore that backup to your new ipad.
iP5
Sep 7, 2010
2,964
136
Toronto
You just login to the App Store on the other iPad and re-install the app.
Sent from my Desire HD using Tapatalk
theorioles33
Jul 21, 2007
925
135
USA
You know what? You are absolutely correct. I was thinking "data" as opposed to "apps"
Brain fart! :)
winlinyin
Nov 28, 2011
You'll be able to sync your apps from your computer's iTunes to iPad2 (the apps will be compatible). You could also use the iTunes backup of your iPad1 to restore onto your iPad2 (so that you can have their settings/stats/content). You can't sync directly from one iPad to another.And there is a step by step instruction on How to transfer Apps from iPad to iPad 2.
Hope it can do you a favor.
Uyiedos
Nov 30, 2011
Just sign in with same Apple id, go to appstore, purchased and reinstall on new ipad
