transferinng contact list to Bluetooth
Mar 24, 2009
how can the contact list from 3g phone be transfered to gx lexus (09)
BrownGem
Feb 27, 2009
1,623
22
Texas
Seems to be a common issue with Lexus and iPhone. Several forums report it cannot be done as iPhone bluetooth doesn't support file transfer. Maybe with the new firmware update this summer and enhanced bluetooth profile...the problem may be solved. Some users suggest using another phone..if you have it..to transfer contacts over or entering them manually...quite a task if you have a long contact list. If you know anything about jailbreaking, there is a program which enables file transfer via bluetooth but not sure if this will work for your purpose.
JustinCarpenter
Mar 24, 2009
57
Michigan
I have the OS 3.0 beta and I paired Bluetooth with a BMW. There is now a blue arrow next to each bluetooth device and when tapped, it takes you to a screen where you can turn on or off syncing contacts and recents.
