Transferring contacts on Android handset to iPhone 6 Plus
rugved1118
Sep 27, 2013
644
Hello,
Can anyone help how to Transfer contacts from android handset to iphone 6 plus ?
Sent from my iPhone 5S
zsuki
Oct 10, 2014
43
Use google contacts syncing service
Sent from Tapatalk
zsuki
Oct 10, 2014
43
Can you tell me how is done ?
Login on your Google account on your android phone and enable contact syncing. Then go to phone (or dialer, contacts, it's different on each phone), copy all your local contacts to google account. Then open google contact on your computer browser, export all the contacts to vCard format. Then open iCloud on browser and import them.
Sent from Tapatalk
tortex73
Sep 30, 2014
147
34
If all your contacts are already synced with gmail, which they should be since you're an Android user, just set up your gmail account on your iPhone and enable contacts syncing in settings. That's it.
zsuki
Oct 10, 2014
43
Yup you can also setup you gmail contacts on your iPhone. You can't add google account and enable contact syncing now because google disabled it. just go to settings-mail and add a vCard account
Sent from Tapatalk
tortex73
Sep 30, 2014
147
34
Sent from Tapatalk
What do you mean google disabled it? Contacts sync just fine for me. I can add a contact on my Nexus 5 and it pops up on my iPhone within minutes.
rugved1118
Sep 27, 2013
644
Thank you both.... I did as per your instructions but there are still no contacts getting synched on iphone. On android it showed as synched with todays date and time.
Dec 15, 2008
5,386
340
Pensacola, FL
http://support.apple.com/kb/HT6407
"...Or when you set up your iPhone for the first time, you can use your existing email account for your Apple ID. During the setup process, you can choose to include any contacts, calendars, or notes that are associated with that email account."
It also talks about using an app to transfer the data. Check it out and let us know what works.
"If you saved your contacts and calendars to your Android phone, you can usually move them to your iPhone with a data-transferring app. Many apps can even transfer your data over WiFi, so you won't need to connect your phone to a computer. You can find several data-transferring apps on the Apple App Store and Google Play store, depending on your country. Here are some examples of data-transferring apps:
Just go to the App Store on your iPhone, find the app you want to use, and install it. If you also need to install the app on your Android phone, download it from the Google Play store. The app will walk you through the steps to transfer your contacts and calendars."
zsuki
Oct 10, 2014
43
Go to settings-mail/contact/calendar, then add a new account, then don't add a google account directly, instead you click Other, then add a CardDAV account and setup your google account here.
rugved1118
Sep 27, 2013
644
What would be gmail server ? It is asking me to enter server.
rugved1118
Sep 27, 2013
644
Server is google.com. and description doesn't matter, you can name it anything you want.
It says carddav acnt verification failed
zsuki
Oct 10, 2014
43
its ok, just tap ok and you will be taken to account screen, go to adcanced settings and turn off, then set the port to 80
zsuki
Oct 10, 2014
43
sorry, turn off "use SSL"
zsuki
Oct 10, 2014
43
I have added account now. But contacts are not yet synched on iphone.
maybe you need to wait few minutes if you got a lot contacts.
rugved1118
Sep 27, 2013
644
Okie will wait. Also how to transfer photos and videos ? Should i use dropbox ? Or is thr a way out ?
