Transferring Contacts to iTunes
T
theraguseos
Guest
I am looking for a "how to" to transfer my iPhone contacts to my PC or existing iTunes library. Can anyones help? Thanks!
N
ngreco
Guest
I was told that if I plug in my iPhone and sync with the existing iTunes it will erase my contacts in my iPhone. Can you confirm?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I believe that even on a PC you will get the message that gives you the option to replace or merge the contacts. You want to merge the two so you do not lose any contacts.
