Transferring files
bkrgrlmphs
Aug 10, 2007
44
I downloaded some free wallpapers and ringtones in .zip files, how do I unzip and move to my iPhone?
What is .png? This pops up after I unzip.
Thnx for any advice.:)
reas0n
670
20
Stamford, CT
www.ohitsjustpete.com
the zip file contains the png file you need the png not the zip extract the png from the zip to your desktop or a folder then there is 2 ways to do it
1. Put them in a folder and sync through iTunes
2. if your phone is jailbroken you can use ibrickr (pc) to put them into ~/Library/Wallpaper
bkrgrlmphs
Aug 10, 2007
44
Thanks I will give it a try.
i upgraded to 1.1.1 I don't have ibricker anymore but thanks away.
