transferring music
You trying to mess with his head? That's mean! :p
I'm sure you meant vice versa
No, actually. Read it again and you'll get it.
I mean that he needs to find the songs that he wants to be on his iPhone, and then import them into iTunes. (Read Slowly.)
- John
mflantin
Nov 29, 2007
100
All right, this shouldn't be as hard as it seems. I just recently purchased my iPhone and I'm trying to add music from iTunes. With an IPod, it was as simple as dragging and dropping into the device. Why with an iPhone, the only way you can seem to sync it is if you sync playlists or your entire library. Is there something I'm missing here? Also what are the benefits of unlocking an iPhone?
iamtko
Sep 18, 2007
2,004
23
Houston
yeah unfortunately you have to sync all of your music to upload it to your iPhone and you cannot drag and drop.
unlocking your phone just means that you can use it with carriers other than AT&T
termleech
Sep 7, 2007
1,154
McPherson, KS
The iPhone doesn't allow for manual management of the music on it (at least I haven't seen the check box for it). What you can do instead is just make a playlist that you drag and drop and the music to and sync only that playlist with the iPhone.
mflantin
Nov 29, 2007
100
Thanks guys, that sucks though. You figure you're paying way more for an iPhone, you should get the same convenience as the ipod. Oh well...
Chris716
Nov 29, 2007
807
IL
well you can select what songs you want sync you just have to have the setting on to sync only checked songs then just check what ones you want to sync but no drag and drop like the ipod
kaser123
Feb 12, 2012
If you still got your problem solved, give a look at sharepod. It is a freeware application that helps you transfer ipod music and photos back to computer.:)
