Transferring PowerPoint email attachment to PC via USB?
Fishfiend
Nov 13, 2011
Greetings to the forum! OK, this is driving me crazy, as supposedly it should be a simple operation--
I'll be on a road trip with my 4G iPhone and a PC running XP. In the car, I would like to transfer any PPT email attachments I receive on my iPhone to my PC via a USB cable (no wifi) in order to work on them, and then transfer them back to the iPhone and email them.
Is this possible? What is the easiest way to to it? On my old Android it was a breeze, but on the 4 it's driving me nuts. Thanks! ps, I'm not jailbroken
Santa
Jul 2, 2009
1,122
115
Colorado, USA
I'm sure there are other ways, but the only way I know of is through an app. So:
1) install an app like good reader or docs to go
2) in your email while looking at the PPT do the little box icon to "send to" the app
3) save the file in that app
4) launch iTunes
5) on the app tab under the application you're using (at the bottom of he page) you can copy the PPT to your hard drive.
Drink two shots and reverse the process to send.
Fishfiend
Nov 13, 2011
4) launch iTunes
Santa, you are a lifesaver, I'd buy you 2 shots for that help--thanks!
rambo47
Apr 4, 2010
528
79
Northern NJ
Dropbox is an excellent solution as long as you can wait for a WiFi connection. If you need all attachments transferred as they arrive then USB is the only route.
  • Like
Reactions: Fishfiend
