Transferring Purchases to IP5: iTunes Version?
ring0_event
Aug 24, 2010
216
I currently have an iPhone 3gs, synced with iTunes 10.7.0.21. My phone is currently on iOS 6.0, and I'm going to buy a new IP5 this weekend to which I'll transfer my purchases. Can I do that with my existing version of iTunes, or must I upgrade to the newer version first (and backup/sync)?
Also, can I apply evasi0n to 6.0, or must I upgrade to 6.1.2 first?
Thanks!
ring0_event
Aug 24, 2010
216
Actually, it worked fine with iTunes 10.7.0.21
Didn't want to take a chance using the newer iTunes...
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Thanks!
The jailbreak program evasi0n has been updated to work for 6.1.2. According to their website, it works on iOS 6.0 - 6.1.2, so you only need to upgrade if the updates are necessary for you. iOS 6.1.2 fixed Exchange Calendar issues.
ring0_event
Aug 24, 2010
216
Thanks, I got my IP5 (on 6.0), and restored using iTunes 10.7.0.21 no problem! Then I upgraded to 6.1.2, and jailbroke without any issues. I've since saved my SHSH blobs too. So thankfully I'm in a good position now. Thanks for your reply!
