Translating the iPhone texts
Rooster
Jul 28, 2007
14
Hi there.
I'm in progress of translating the iPhone into swedish. Now, I have finished the home-screen and some other texts like "slide to unlock" etc. when those files where avaible to download on the web.
But now I would like someone of you guys to help me out.
I can't get my WinSCP to work so I can only use .strings-files that people aldready have uploaded on the web and upload them via the
C:/WINDOWS/System32/cmd.exe
So if you do have a working WinSCP I would like you to give me all the files required to translate the rest of the iPhones texts.
Please contact me by PM if you want to help.
Rooster
Jul 28, 2007
14
Hi again. Sorry for the double post, but I solved the problem with the command getfile. If you are gonna use this command yourself, notice it will only work within the directory you are located in. So if you want to get for exampel SpringBoard.strings, you'll have to enter
cd /System/Library/CoreServices/SpringBoard.spp/
getfile SpringBoard.strings
I'll come back and tell you if I succeed with my translation ;)
Rooster
Jul 28, 2007
14
Now I need your help with this.
The iPod-part is a little tricky. the file
Applications/MobileMusicPlayer.app/English.lproj/Localizable.strings
...contained some texts from the iPod part, such as "All Albums" and "All Songs". But where can I find and edit the parts that can be viewed on this image?
