Tried restoring iPhone using ibrickr, getting blue screen
thabayboy52
Jan 27, 2008
52
i used ibrickr to downgrade my phone down to 1.0.2 state and jailbreak it. when i attempted to jailbreak it the screen turned blue with the connect to iTunes sign then the script keeps running. it does this for a while the boots out of it not jailbroken. i tried restoring the phone but it just goes back to the same blue screen. so im basicsally stuck in v1.0.2. i've used this program many times and this is the first time this has happened to me. can someone please help?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Why downgrade to 1.0.2? Downgrade to 1.1.1 then up.
So just do a restore to 1.1.1 and begin the jailbreak.
thabayboy52
Jan 27, 2008
52
I tried to do that but it just goes to the blue screen that says connect to iTunes.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Do you have the latest iTunes 7.6 as well as the latest restore files, something maybe corrupted. Also after iTunes make sure to reboot the computer.
thabayboy52
Jan 27, 2008
52
yes I have the latest version of iTunes and restore files
KNK
Jul 22, 2007
2,391
Stevenson Ranch
If your iTunes see the phone connected you could use the DFU to force a restore.
Get the DFU here
Take the newly extracted DFU folder, right-click it, and select cut. Then open up My Computer and navigate to your Local Disk (C . Right-click anywhere in this folder and click paste.
Go to the start menu and click Run. When the Run dialog pops up, type in the following:
c:/dfu/dfu iBSS.m68ap.RELEASE.dfu
Now hit OK. This will force your iPhone into DFU mode and will lead to a restore.
thabayboy52
Jan 27, 2008
52
I will try this when I get home... Will this work with vista?
thabayboy52
Jan 27, 2008
52
ok so i did what you said and nothing happens at all. the dfu program just flashes on the goes right back off
nvm... it came on and says "no error"
Sep 7, 2007
are you sure you're not clicking on the DFU executable instead of typing the proper command into the Run bar?
thabayboy52
Jan 27, 2008
52
i figured it out i somehow got my phone to boot out of it using ibrickr. thanks for the help
plazobi
Feb 14, 2008
Get the DFU here
I tried this, but nothing happens. The program says: "s_Looking for iPhone"
And it is connected!
My iPhone still shows me the restore window.
What do I have to do?
