Trouble changing carrier logo on iPhone
kinjalk
Oct 31, 2007
32
Hey, i have unlocked jailbroken 1.1.1 and i can't seem to change my carrier logos. I have tmobile and i have tried all the logos nothing works any idea why? Everything else works except the logos. Any help? suggestion? will be appreciated.
Thank you
Try downloading 'Make It Mine' from Installer. It let's you type in custom carrier logos and may be your solution. Maybe not.
- John
kinjalk
Oct 31, 2007
32
- John
Cool will give it a try.
tiguy99
Nov 28, 2007
154
Chicago
Kin have you rebooted yet? Turn the power off and then back on again. The new logo should pop up in the upper left corner soon as it comes back up. That's what my phone's done between each upgrade/unlock between the different firmwares
kinjalk
Oct 31, 2007
32
Yep tried it but no luck, i did download "make it mine" but that only lets you write soemthing instead of logo. So still trying to figure it out.
Dec 13, 2007
25
utah
go to your installer, and download customize and a bunch of the add ons. and you can change it to different carrier logos or halo, XXX, etc. you can also just do a search for carrier logos and manually ssh them to your phone to the following directory-
/System/Library/CoreServices/SpringBoard.app/Default_CARRIER_ATT.png
/System/Library/CoreServices/SpringBoard.app/FSO_CARRIER_ATT.png
replace those files above with the ones you download.
