Trouble getting a 5 icon dock
djentee
Sep 17, 2007
24
I'm having trouble getting a 5 icon dock. I've tried both rSBT & SB setting it to 5 icons but no luck. This issue came after i installed the latest version of Customize. Any ideas? Thanks in advance.
Stevonw
Sep 14, 2007
560
UK
i'm having troube getting a 5 icon dock. I've tried both rSBT & SB setting it to 5 icons but no luck. This issue came after i installed the latest version of Customize. Any ideas? Thanks in advance.
I think it may be a bug or glitch with rSBT. I and others have experienced this same problem.
The easy and quick way to get everything back to normal is to go into rSBT and then choose settings at the bottom right.
After that hit the firmware button and it asks you to restore to normal, hit ok and everything is back.
Personally I'd wait for the new version to come out and fix these bugs.
djentee
Sep 17, 2007
24
u da man! i'll wait for da next version. Thanks for ure help...
