Trouble with Jailbroken iPhone! Please Help!
Mar 12, 2013
Hi, Just received a iPhone 3GS that was jailbroken. I plugged it up to charge and it showed the battery screen. AS it was charging it went to the Apple screen then went to a screen that showed a USB plug in to iTunes. So I plugged my phone to the computer and iTunes came up and said your iPhone has to be restored. Should I restore it? What do I do? Is it even Jailbroken? Thanks!
5,578
Moved to iPhone jailbreak.
Yes, you'll need to restore it. You can jailbreak it with evasi0n after you restore it. Is the phone unlocked for use with a carrier other than the one that it's tied to?
Mar 12, 2013
I don't have the program that jailbreaks it. I bought it offline. Is there a way to tell what carrier it is connected to? Thanks!
5,578
Duplicate threads deleted. Please only start one thread per topic.
Mar 12, 2013
sorry new and went thread crazy... don't know how this works exactly yet
5,578
Are you going to be using AT&T or T-Mobile? Do you know if the phone was unlocked? The seller probably would have said if it was unlocked.
Mar 12, 2013
I am going to use it for AT&T sim card... it was sold as an unlocked phone
5,578
1. What's my next step after that? 2. Was it truly unlocked before I bought it?
1. The next step is jailbreaking it if you want it jailbroken.
2. This is information the seller should have given you. Did the seller say if it was an IMEI unlock or a software unlock with the iPad's baseband? If it's an IMEI unlock, it will just restore normally. You can still fix it if has the iPad baseband, but it's more work and it causes errors with the restore.
If you don't know, just put your SIM card in it and try to restore it in iTunes. Post the iTunes error codes here if you receive any.
Mar 12, 2013
didn't say...It won't let me download that program you told me that would re-jailbreak my iPhone! Whast do I do?
Mar 12, 2013
I got error code (-1)
5,578
Error code -1 indicates that there may be a hardware problem. However, I wouldn't give up on it yet. The iPad baseband was likely used to unlock this iPhone and it causes a variety of problems, including restore errors. For future reference, an IMEI unlock is far superior to software unlock applied after modifying the baseband. IMEI unlocks are permanent, the phone can be activated with any SIM, and they don't cause restore problems. Look for that in the details when and if you ever purchase another iPhone. Personally, I would avoid iPhones that had the iPad baseband because I just wouldn't want to deal with the problems it causes. That being said, they are fixable if you're willing to put in the time and research involved with fixing them. Knowing a little bit about this phone would make the process easier (if it does have the iPad baseband, what carrier it's locked to and if it has any SHSHs on file). Since you are receiving errors when restoring to 6.1.2, I would try putting it in DFU mode and shift+restoring to an older firmware and downgrading the iPad baseband with the latest version of redsn0w. You can only restore to old firmware versions if the previous owner saved the SHSHs for them in Cydia.
http://www.redmondpie.com/how-to-do...05.13.04-baseband-for-unlock-and-working-gps/
http://www.iphonehacks.com/download-redsn0w
