trouble with setting up emails
jam75944
Aug 25, 2007
9
HI ALL!
finally got my iPhone! I am having trouble setting up my email accounts..yahoo worked no prob. When I try gmail or an additional email such as hotmail I get this:
"cannot connect using ssl. Do you want to try setting up the account without ssl" Than I try without ssl and I get "the POP.gmail.com is not responding.....
What does this mean and how do I fix this.
thanks all!
jam75944
Aug 25, 2007
9
Goto settings, mail, your account, advanced, then make sure incoming uses SSL is set to off. Try that and see if it works.
nothing, no luck. DO I use imap, pop, or exchange to set up a hiotmail account?
Can I find step by step instructions on setting up email accounts?
thanks!
jam75944
Aug 25, 2007
9
ok, with a little research I found out you cannot have a hotmail account with the iPhone..however my gmail account still does not work...."pop.gmail.com" is not responding.
anyone else experience this?
Kipper
Do u have the correct password set for both incoming and outgoing? On the account settings do u have the correct path under mail server host name? I have a verizon POP acct. and mine is "incoming.verizon.net" to give u an example. Just trying to pinpoint where this problem is for u.
jam75944
Aug 25, 2007
9
fixed gmail! thanks!
still annoyed I cant get hotmail!
