Trying to copy all my photos to PC
dankduke
Sep 11, 2007
278
Austin, FL
so i hooked up my iPhone to my pc and cannot grab all my photos from the phone...
i go into my computer and the iPhone is not listed there...
under device manager it shows digital still camera with a yellow exclamation
i click check for solutions...and it says could not load driver software..
how can i grab these photos!
thanks
danks
glsda
Oct 17, 2007
1,440
50
California
thanks
danks
I think you are going to have to use some software like copytrans to do it. Do a search on the forum, 'THIS copytrans', no quotes of course and you will find discussion on third party software for the PC that will do this. You don't have to be jail broken to use it. I bought copytrans and it works well, www.copytrans.net
Swagger
Jul 9, 2007
2,076
Fort Lauderdale, Florida
web.me.com
You might need to download the latest version of iTunes which has the latest iPhone drivers. Try also using a different USB port. If you have the latest version of iTunes then re download iTunes as your version may be corrupt. You should not have to purchase ANY software to get your photo's off of the iPhone. Are you using a Mac or PC? Mark
P.S. Another thing you might want to try is rebooting your computer while the iPhone is still hooked up via USB. Sometimes a fresh boot will find your iPhone as the drivers are restarted. Try this method first....Mark
Draven
Jun 5, 2007
Right-click the device in the Device Manager that has the exclamation mark and uninstall the driver. Then unplug the iPhone and plug it back in. That should do well for getting the phone to show up.
melody
Dec 18, 2008
I suggest you use ipcsuite to copy your files to your computer
nickon
May 25, 2010
ipod to computer
to copy ipod to pc is very easy through a simple software which i founded in website ...
If you want you can also download the software and starting copying ipod to pc
______________________
[FONT=&quot]http://ipodtoiTunes.net/[/FONT]
Mar 25, 2013
Plugin your iPhone to the computer without iTunes running
1. Wait for a popup asking you what you want to do with the device
2. Select “View Content”
3. Find your photos through the folders that are displayed
4.Copy in Windows as usual
