trying to mod with Vista.
kevinc650
Jul 19, 2007
9
is there any where that show how to mod using vista? not xp? cause vista is a little bit different, and i was just having a little trouble trying to figure everything out. thanks if anyone can help.
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Same as XP stuff, I use Vista and never seem to have problems with most modding methods. Whatcha trying to do?
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
I started modding mine on vista, but i said screw it and just used my notebook to do it. (Which has xp)
kevinc650
Jul 19, 2007
9
im trying to add some ringtones to the phone. its actually at the very first step, its the step where you have to uncheck "Hide extensions for known files" i believe that is where i got stuck. sorry im a noob with computers.
when you have the update in a window theres no part to open up the folder options.
unknownentry
Jul 19, 2007
204
Knoxville, TN
www.iphonesurge.com
well its actually at the very first step, its the step where you have to uncheck "Hide extensions for known files" i believe that is where i got stuck. sorry im a noob with computers.
You need to go to view > toolbars > show menu bar or something like that...I'm at work now, but if you can't get it I will tell you exactly later this afternoon.
kevinc650
Jul 19, 2007
9
i actually got all the way down to where it says on jailbreak booting iPhone. thats normail rite? iv been waiting for a while.
unknownentry
Jul 19, 2007
204
Knoxville, TN
www.iphonesurge.com
Are you using iBrickr? If so jut follow the on-screen instructions. It does a great job walking you through the steps of jailbreaking!
kevinc650
Jul 19, 2007
9
Check this out:
http://cre.ations.net/creation/ibrickr
You may have to restore? Don't know what you've done so far, it may be easier to start fresh.
i got all the way to
*At this point Jailbreak will begin performing mysterious operations on your phone
so my phone has a yellow triangle that says please connect to iTunes, while jailbreak says...booting iPhone...
