Trying to restore backup from iCloud
randuff
Aug 3, 2010
19
Fort Worth
So I am trying to set up my 4s using iCloud restore. Time left is now at 4 hours (started at 6.)
I am not at home so I can't connect to iTunes. Is there a better way to set this phone up? Other than setting it up as a new phone.
I am going from a 4 to a 4s
imamac
Mar 23, 2010
279
If you have the time at work, I'd let it keep going and hopefully it will finish before you have to leave.
Otherwise, I'd try connecting directly to iTunes when you get home. It may be faster. But I've read some are having trouble either way.
imamac
Mar 23, 2010
279
I know, I know. At least you have yours. :)
I'm still staring out the window watching for the UPS truck.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Servers are getting slammed today, no reason you should wait that long. I would just do it once I get home.
mori
Nov 16, 2007
90
i got mine and you feel lucky u got to activate yours,, i cant for mines..lol
randuff
Aug 3, 2010
19
Fort Worth
Ok so I did some checking and I went to manage my icloud and turned off some apps, namely the 9GBs! of photos, videos. After I turned those off it took 5 minutes. Up and running and playing with Siri (Australian female voice :p)
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Greetings!
Just got my 4S swapped out at the Apple store.
I set it up as new at the store.
I'm trying to restore from backup, but all I se on my computer are older from a few weeks ago.
If I go into iCloud on the phone, then > storage & backup > manage storage, I see one from yesterday. How can I backup from that?
showguy
Dec 2, 2007
769
Long Island, NY
How content is restored to a new device
When you go through Setup Assistant on a new iOS 5 device, choose "Restore from iCloud Backup" and enter your iCloud account and password. You will see the three most recent backups for each of the devices on which you enabled Backup. Choose which backup to restore from.
After your device restarts, your settings and accounts are restored and Backup starts downloading your purchased music, TV shows, apps, books, Camera Roll, and other content.* You may be prompted to enter the passwords for all accounts enabled on your device.
A progress bar will appear underneath the apps that are being downloaded. To prioritize the restore of a specific app, tap its icon. Restore will attempt to download the same version of the app that you had installed previously. If that version is no longer available, the latest version of the app will be restored.
If you are using iTunes Match (U.S. only), you can download any of your songs, albums, or playlist from iCloud after the restore is complete.
To check if the restore is complete, go to Settings > iCloud > Storage & Backup.
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Got it sorted, thanks...
To conserve time, I set it up new @ Apple store and backups on home PC were a few weeks old.
I checked on the iPhone when I got home and saw some more recent available in iCloud, but could not access them since all I was doing in the Reset menu was Reset All Settings.
Once I did a complete wipe with Reset All Content and Settings, I was able to gain access to those more recent iCloud backups on the4S.
Nice to be able to restore right from the device and not even have to plug it in anymore......
showguy
Dec 2, 2007
769
Long Island, NY
Backing up to ICloud is very convenient if you need to restore when away from your PC with iTunes. I stopped using it because the backup process is real slowwwwwwwww.
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Not sure what u mean.....
Had to restore both mine and mrs snowtrooper's over the weekend since I had the Apple store swap out both our 4S's.
Both restores were via iCloud on each device since neither of us had a recent enough backup on our iTunes/PC/laptop accounts.
Mine is only 180MB and still took 2 hours.
Hers is around 3GB and took something like 5 hours.
This is via our WiFi cable modem with a bottom tier download speed of 3.19Mbps.
5 hours. Yikes. It would be much, much faster to restore it from backup on the computer. I've haven't tested it yet, but I'm sure you can use an iClould backup in iTunes on the computer. My restores from backup usually only take 10 or 15 minutes.
15,385
1,023
Yeah, iPhone backups are ginormous - usually at least 500MB, and can be multiple GB. When restoring from iCloud, your phone has to download that whole file, and that will take a pretty long time even with a relatively fast Internet connection.
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Yikes indeed, Mindi!
It would be faster, but I could not find out quickly in the middle of the night if I could access the iCloud backup through iTunes, so I went with what I had....
Camitampa
Apr 1, 2009
40
Tampa Fl
I had my 64g iPhone 4s replaced at the Apple store on Saturday and had it restored from an iCloud backup. Everything but the apps and music was done before I left the store. The apps took less than twenty minutes once I was on my home wifi. I had to re-sync the music. All of the important stuff ie contacts and messages were available almost instantly. I was happy with it.
Sent from my iPhone 4S using iCafe app
