Trying to update an iPhone 3GS No LUCK
Narf48
Mar 15, 2010
88
My 3GS has operating system 4.2.1 on it, when you plug it into iTunes and check for a software update, it says you have the most current version of software available, now ive updated iTunes to ver 5 and i put the phone into DFU mode as well as just trying to update it the normal way and nothing works, any suggestions would be great thank you
Target
Oct 16, 2008
1,139
161
The Great State of WV.
Two really simple questions: 1) are you clicking the update button on iPhone screen? 2)do you have the latest iTunes update?
Target
Narf48
Mar 15, 2010
88
Yes and Yes, I updated my phone and this is a friends phone, and yes it is his computer with his current iTunes, I cannot figure it out? it should go right away
Target
Oct 16, 2008
1,139
161
Hey here's a thought...wasn't there like a 4.3.5 update in between your's and iOS5? Did you try that one or did iTunes default to iOS5?
Narf48
Mar 15, 2010
88
right now the phone has 4.2.1 on it I tried 4.3.5 and 5.0 no luck with either
