Turn off WiFi to save battery?
elaines
Aug 9, 2007
An Apple guy suggested we turn off the WiFi when not in use to save battery life. If I leave my iPhone in the charger each night, is it still necessary to do the turn-off step?
Thanks!
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
Thanks!
i leave mine on when its on the charger at night, doesn't seem to make much of a difference other than maybe it will charge a little faster with WiFi off. but yes, when it's off the charger, the WiFi is a huge battery hog. if you are not using it, definitely make sure it's off. if you do this, you will be surprised just how far the battery will go.
schmots
Aug 20, 2007
I can verify that I get much better battery life only turning on wifi when I need it and not just leaving it on.
