Tweak to have unlimited SMS Inbox storage
wildonrio
Jul 4, 2007
2,002
Provo, UT
EDIT: Works again with 1.0 update!
Tired of the SMS inbox almost full warning? Here's how to get rid of it.
1. Go to Installer, push Sources, then Edit, then Add.
2. Type in http://iPhone.totalmatrix.net, then Done, then Refresh.
3. Go to Tweaks (1.1.1) and install "Remove 1000 SMS Limit"
4. Restart your phone, and enjoy unlimited storage!
Special thanks to piranha for showing me how to do this!
How this app works: All messages past 700 will automatically be archived in a separate folder for you. This will keep your SMS inbox screen free from slowing down because of too much data. To be able to view all of your old messages, you must install SMSD. All your messages will be viewable in SMSD, but only your most recent 700 will be available in the native SMS app from Apple.
Sep 29, 2007
348
omg thank you so much. I have this problem so much
Chris716
Nov 29, 2007
807
IL
do you have the correct sources and what not installed on your joint...
fahad20
Oct 3, 2007
will this work for 1.1.2 also?If nt is there any way to do the same in 1.1.2
thnx!
thepunisher1991
Jul 30, 2007
72
thnx!
but do you know what utlcl or something like that is used for
because I tried dowloading the update but I said to download some pack but first I need to know way I'd for
Sep 29, 2007
348
I thought this would make it so it wouldn't be full ever but after one day its full again and yes I do have it installed. Did I do something wrong I have everyhing installed, restatted my phone, but yet I keep having to deleat messages.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Thanks for letting me know. This program is very new and could possibly not work. I will let the developer know.
Sep 29, 2007
348
I am restoring right now and I am going to try to see if it works after. I will let you know but I am having problems downgrading like normal.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Are you on 1.1.2? The developer only tested it on 1.1.1. He said it should still work on 1.1.2, but he said he couldn't guarantee it.
Do me a favor and if you have SMSD installed, look in there and see if you have any messages showing up in your Inbox or Outbox. On my phone, they are both empty even though I have plenty of texts in my original SMS app. I haven't gotten the "almost full" message yet but if you also have an empty Inbox/Outbox, maybe we have the same problem and I'll get the almost full message soon.
Sep 29, 2007
348
I was just about to say that. I have no messages in my SMSD inbox and outbox BUT I do have all my messages in weTool. The thing was it was showing the messages earlier this morning but when it stopped and I had to start using weTool, then a few hours later when I get some more messages it said it was full. I am trying to restore it right now but still having problems and if you have time, please look at my thread in iPhone software.
I think i might be doing something wrong to the firmware because I keep getting error (1). I get my 1.1.1 firmware in a zip file and I convert it to .ipsw but I then thought I should change it to iPhone1,1_1_Restore.ipsw and its still not working.
Chris716
Nov 29, 2007
807
IL
im really starting to not like this app...
buttsecks
Oct 1, 2007
have it on installer but says not to install yet. what up with this thing?
wildonrio
Jul 4, 2007
2,002
Provo, UT
Here's what the author PMed me just recently:
Ok, I see what's happening now.
The main command of the script is not getting executed, thereforee no changes actually are done to your system.
If you have terminal on iPhone (or if you can SSH to iPhone), execute this manually to get it enabled:
/bin/cat /var/root/smsON.sql | /bin/sqlite3a /var/root/Library/SMS/sms.db
Above is one line and capitalization matters.
In the meantime I'll try to find why it's not running via installer on your system.
To reply to posts on that forum (he's referring to this forum): no changes to their system has beed done apart from the change of SMSD executable (which can be easily reversed by reinstalling SMSD).
I'll keep you updated tomorrow.
Sep 29, 2007
348
Sounds good Ill try it tuesday, I have exams all week but after that I hopefully will have a jailbroken iPhone if I ever get it to downgrade.
