Twitter Notifications not working on iPhone 6
Dec 15, 2008
5,386
340
27
Pensacola, FL
Have you checked Settings - Notifications to see if it changed? If you reset settings at some point then you have to redo them all.
OK, you said they are set up the same. That is strange then.
coop1701
Jun 30, 2007
899
114
43
Do you use the standard Twitter App or another Twitter Client? I myself use Tweetbot. It's notification settings are actually inside the software.
28,365
5,506
Good suggestion, coop1701, I currently use the standard twitter app (on both devices). Europa, yes I have checked both places several times. All set up correctly.
Deleting and then reinstalling it will prompt you to set up the notifications again which might fix it.
bkford
Jul 30, 2009
150
MO
scrappermamo.blogspot.com
No chance at all, but what is also weird is that he also does not receive notifications of MY tweets. I haen't been able to test, but I don't believe he is the ONLY one whose tweets I am not getting notifications from.
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
Maybe you could try this… Go to your son's profile, click the gear icon, then click on "Turn on mobile notifications." Have him do the same on his end for your profile:
Ledsteplin
Oct 29, 2013
4,819
985
65
Florence, AL
As a last resort, download a free Twitter client, set it up for notifications. Hide it in a folder with Newsstand and continue using the Twitter app. You'll get your notifications from the client. I've done that before. Or just use the client as coop suggests.
Sent from my ancient but trustworthy iPhone 5.
bkford
Jul 30, 2009
150
MO
I did look at other free twitter apps and didn't really see one except for a couple that are only for posting?
Ledsteplin
Oct 29, 2013
4,819
985
65
Florence, AL
I used Echofon for a while. It had notifications that worked well. I finally got Tweetbot when it was on sale. Echofon had added too many ads. But it would work great just for the notifications.
Echofon for Twitter by Ubermedia, Inc.
https://appsto.re/us/644fr.i
28,365
5,506
So notifications are working now, but not for one or more of the people you follow. Okay, I would try deleting and reinstalling it again, but this time log out first. I've seen that extra step help with notifications in the past.
