TXT MSG + Time
__DorkSterr
Jan 20, 2008
90
Why is my txt msg time all wrong? the txt msg I send is correct but the ones i receive are always wrong.
gotpancakes
Nov 24, 2007
319
yup. Upgrade to 1.1.4 and it will be fixed.
phred26
Feb 17, 2008
51
Oakville, ON, Canada
I had the same problem, only way to fix it is to upgrade to 1.1.4, don't waste your time trying to find a fix and searching the forum because I looked, trust me, there is no fix, you have to upgrade
Happened to me on 1.13, upgrading fix it.
- John
burniksapwet
Jul 5, 2007
553
Use iTunes. Restore everything first then upgrade to 1.1.4.
Apr 29, 2008
So just to make sure all I do is press the restore in iTunes then do the upgrade to 1.14 and then after that run ziPhone and unlock 1.14. Is ZiPhone 3.0 okay to use?
