Typed wrong password, How do I correct it?
Skipper
Jul 18, 2007
45
Ok, I just restored after 1.02 release, and I made the mistake of typing in the wrong password for my Wifi at home. It doesn't say that the password is incorrect, nor does it give me the option to try again... it just goes to edge and no wifi. I try to select it from the wifi list, and it says unable to connect to that network. Is there a place to retype the password? I will be pissed if the solution is to restore AGAIN!
Please help! thanks!
eplantz
153
just go into SETTINGS, WiFi and select the WiFi you are using now (blue icon over to right) and then press the FORGET THIS NETWORK button.
then, you can start over in connercting to this WiFi
Skipper
Jul 18, 2007
45
ahhhh! I thought that would remove the network from the list forever. Works perfect now! Thanks!
