Ugly Battery Indicator
Jul 15, 2007
39
MA
Hi guys,
on 1.1.2 I changed my battery indicator to the numeric one. I hate it and now Im on a jailbroken 1.1.3 and I want my plain one back. Can someone help me do this?
Thanks!
Jul 15, 2007
39
MA
Obviously...but when I revert to my backup the ugly indicator comes with it. I don't wanna loose my settings, web apps or texts-
which is why Im asking how to remove it. There was an app in installer before that allowed you to tap the battery to get a numerical value. Im looking for that.
Thanks!
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Download the orginal from MMi. Then SSH into your phone and replace the png files. Or use customize to change it back.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
Ok. I see. That happened with my carrier logo sometime back....The fix I used was ibrickr and manually replaced the png file.......that's what started the whole mess..I think I after a while of using installer, strange things start happening. Certainly if you're always tinkering around. A restore of course is a fresh start. good luck
forkee
Sep 6, 2007
348
you mean this?
Settings->Advanced Preferences->Battery Level: "Off"
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Yes - I forget the name of the program, but it is a 3rd party add on.
forkee
Sep 6, 2007
348
sorry, i forgot it was an add on. its called advanced preferences by skylar. i think its in the touchrepo repository. here it is if you don't have it
touchrepo.com/repo.xml
