Ultimate Icon Theme
katra
Jun 26, 2007
229
hey guys...i just made my very own icon theme ! ...it took me several hours to make but it is now complete.!:laugh2:
some icons i made from scratch and some i modified from OSX.
let me know what you guys think !:)
bottom icons..
Stevonw
Sep 14, 2007
560
UK
i can tell you right now that more than 50% were not made by you....most are icons from OS X :mad:
None the less quite good :p
patrick_83
Oct 11, 2007
310
Illinois
I think the icons look good, but i still like the PlainJain icons so i can see my wallpaper better :laugh2:
theone77
Oct 18, 2007
73
can u share how to do this step by step? thanks
scandalex
Sep 16, 2007
771
This was ackowledged by the OP, so I don't get the point you're making?
iNoob
Sep 2, 2007
24
Would it be possible to post the icons in a zip folder? They are sick, but I would like to be able to pick and choose which icons I use. :)
Make an iTunes icon.
It's not such a big deal with this theme because the icons are colorful - but take PlainJain for instance. All of your apps have cool, transparent icons - except iTunes. Which for me, defeats the purpose of using said theme.
katra
Jun 26, 2007
229
hey iNoob.....i will zip up my icons and post them shortly.......:)
gametroll
Oct 18, 2007
Really?
Run an update in installer for PlainJain (or PlainJainDim or BlackJainDim) and you should have a transparent (as transparent as the rest) icon.
Let me know if you don't, might need to update the installer.
iNoob
Sep 2, 2007
24
By the way, where did you get the background that you're using?
Chris Hyde
Oct 27, 2007
97
how would one go about loading them? sorry.
katra
Jun 26, 2007
229
sorry guy's ...i forgot to include the background wallpaper in the zip file....:eek:
but here it is....just right click the image and save it to your desktop...:)
katra
Jun 26, 2007
229
to load the icons i use ibrickr....(for windows):)
in ibrickr i go to "files", then "applications" and go to each individual app folder and replace the "icon.png" with the one's in the zip file.;)
Chris Hyde
Oct 27, 2007
97
1.1.1 will not work with iBrickr. Any other suggestions?
katra
Jun 26, 2007
229
yes...i also had 1.1.1 ..but decided to downgrade to 1.0.2 beacuase i just missed my apps and my mods to much.....;)
if you ever decide to downgrade....ibrickr does it for you .....so simple..all you have to do is make a few clicks ...and presto! 1.0.2 again !:laugh2:
Chris Hyde
Oct 27, 2007
97
The "ipod" icon does not match the one on your first post. It shows up as an orange square with a clipart ipod in it. I like the one on your post with the actual pic with the headphones.
