ultrasn0w vs. purplesn0w
cdc515
Jun 10, 2009
107
I just came across geohots latest release a new unlock for the iPhone 3gs has anyone tried this unlock does this solve all the errors that ultrasn0w had.
lets hear all your opinions on this new unlock and this old/new unlock
partizan
Feb 25, 2008
302
Milton, Ontario
I tried both and I would not recommend the purplesn0w. Totally froze my iPhone. Looks like I need to restore. Nothing is working.
On the other hand ultrasn0w worked like a charm.
BTW I jailbroke with purplera1n
partizan
Feb 25, 2008
302
Milton, Ontario
No restore needed, thank goodness. In order for purplesn0w to work, once you download it in Cydia, you need to reset network settings and disable 3G. I'm on Apple approved carrier (ROBBERS, I mean Rogers), but you still needed to disable 3G. Once I did that it worked fine, but Edge was slow as hell (96 Kbits/s down and 48 Kbits up, compared to 4109 Kbits down and 264 Kbits up on 3G).
I think I'll just stick to ultrasn0w if I need to take my 3GS to Florida (I use T-Mobile in FLA), but again I still have my 2G nicely JB'd and unlocked on 3.0. Another nice thing about ultrasn0w is the SBSettings ON/OFF toggle.
Hope this helps...
