Unable to receive incoming calls on iPhone 4?
rugved1118
Sep 27, 2013
644
Hello,
My wife's iPhone 4 gets hanged suddenly. She can see incoming calls but is unable to receive them and can see all messages also. Can anyone give me a remedy?
Sent from my iPhone using iCafe Forums
-- iPhone5, iPhone4 and ipad2-wifi+3G
Ledsteplin
Oct 29, 2013
4,849
1,001
66
Florence, AL
Hello,
My wife's iPhone4 gets hanged suddenly. She can see incoming calls but is unable to receive them and can see all messages also.
Can anyone give me a remedy ?
Have you tried "Reset Network" in settings?
rugved1118
Sep 27, 2013
644
I tried ... Seems to work fine now... Hopefully this should work. If problem still persist, is there any other solution ?
Ledsteplin
Oct 29, 2013
4,849
1,001
66
Florence, AL
See how it goes for a while.
rugved1118
Sep 27, 2013
644
Hello,
The problem came up again. I did 'Reset network' 15 days back again and the problem come up after every 15-30 days. Is ther any reset to be made or aby other solution ?
5,578
Hello,
Try a restore to factory settings or resetting all settings. If you don't want to do that. Just reset the network settings every so often.
RoofMonkey
Jun 21, 2010
8,895
2,059
If it's every 30 days, it sounds like it's running on a billing cycle.
Ledsteplin
Oct 29, 2013
4,849
1,001
66
Florence, AL
@rugved1118 , You might want to consider an iPhone upgrade for your wife. There's some great deals on the iPhone 5c. My wife got one free on contract with Verizon. She loves it. A factory restore may fix the 4, but it won't get iOS 8 later this fall.
rugved1118
Sep 27, 2013
644
Will factory restore delete all data and apps ? What would happen to purchased apps such as whatsapp and others ? There are few which are downloaded directly through wifi which is not seen in iTunes which i feel is strange...
rugved1118
Sep 27, 2013
644
Hello,
There is no contract scheme available in india which is the saddest part as compared to other countries..
5,578
You'll lose your texts and settings, but data that is synced through iCloud will restore when you login to iCloud. Apps can be synced back on for free. Apps that have been pulled from the App Store can be synced back on as long as you sync with iTunes on a computer. Otherwise, they will be gone for good.
rugved1118
Sep 27, 2013
644
You said data will be synced using icloud but i never use icloud. Instead i have a regular backup using iTunes from my laptop. So, can i restore from iTunes after applying factory restore ?
5,578
That's not a factory restore; it's a restore from backup. Restores from backup are less likely to solve problems. I recommend setting up iCloud syncing even if you decide not to restore. I can't think of any reason not to use it. It's a great service and it's free. You don't have to rely on those backups for things like contacts and bookmarks if you use iCloud syncing. You can continue to backup in iTunes if you want. You don't have to use iCloud for your backups to use iCloud for syncing notes, bookmarks, contacts, etc. iCloud syncing and backups are two different things that are independent of each other.
