Unable to see apps on iTunes which are downloaded from WiFi directly on idevices
rugved1118
Sep 27, 2013
642
Hello,
I am Unable to see apps on iTunes which are downloaded from wifi directly on idevices.. May i know the reason ?
Sent from my iPhone using iCafe Forums
-- iPhone5, iPhone4 and ipad2-wifi+3G
28,365
5,506
Hello Europa,
I tried clicking checkboxes mentioned in your screenshot but its still the same. The ones i have downloaded using wifi cannot be seen in iTunes of my laptop.
These are apps that you downloaded with your account rather than your friend's account, correct? They won't transfer if they were purchased from another account. If you used your account, make sure you're signed into the same account in iTunes on the computer and select transfer purchases.
